Nyt huikeaa lisäapua huononäköisille !! Kannattaa tutustua jos olet kohderyhmää.
https://www.sonyalpharumors.com/sony-tidbits-1599/
https://www.youtube.com/watch?v=IyeOSsUq-CE
Sony introduced an amazing new electronic viewfinder for visually impaired users at this year’s CP+ Camera & Photo Imaging Show in Japan. The RETISSA NEOVIEWER uses a QD Laser to help people with low vision to use a camera. Let’s have a closer look at this unique and revolutionary new product.
Read more:
https://www.cined.com/sony-retissa-neov ... red-users/
Sony DSC-HX99 RNV RETISSA NEOVIEWER
Re: Sony DSC-HX99 RNV RETISSA NEOVIEWER
Key specifications Sony DSC-HX99 RNV
Projection method: Laser retinal scanning
Light source: RGB semiconductor laser R:635nm、G:520nm、B:450nm Typ.
Horizontal viewing angle: approx. 60-degree angle
Aspect ratio: 16:9
Resolution: Equivalent to 720P (1280×720)
Color: 8bit full color (256 levels)
Operating time: about 4 hours
Charging time: about 3 hours
Refresh rate: Approx. 60Hz
Image input: 1080p/60p and 720p/60p, PAL mode is not supported
Battery Type: Lithium-ion battery
Input: DC5V (USB Micro-B) Max.1.5A
Capacity: 3.6V/3200mAh(12Wh)
Size: width 137mm/5,4 inch x height 120mm/4,7 inch x depth 103mm/4,1 inch
Weight: 330g/11,64 oz
Digital still camera: Sony DSC-HX99
