Pentaxilta uusi APS-C runko
Re: Pentaxilta uusi APS-C runko
In developing image quality at PENTAX, one of our most important tasks is
in maintaining consistency in image rendition across the camera’s entire ISO sensitivity range
This means that, regardless of how the ISO sensitivity fluctuates, the camera must produce similar rendition of the image at all sensitivity levels.
To achieve this, we had to fine-tune the camera by optimizing the consistency in noise and sharpness.
Working to minimize the generation of chromatic noise in the high-sensitivity range sometimes results in unfaithful color reproduction.
We were able to develop an original image processing technology that assured distinctive PENTAX rendition even at super-high sensitivities. In the PENTAX K-3 Mark III, we moved a step closer to achieving the ideal PENTAX image quality by incorporating the PRIME V imaging engine and the new-generation accelerator. While delivering beautiful images with smooth outlines and true-to-life colors,
the camera also prevents incorrect adjustment of black levels. It even provides a super-high top sensitivity of ISO 1,600,000. Because it also provides a selection of Custom Image modes and a wide range of adjustable parameters, the number of combinations with ISO sensitivity settings is almost limitless. By conducting a series of sensibility evaluations to analyze a great number of images captured by our image quality designers, and by using the evaluation results for further upgrading, we were able to successfully
fine-tune the camera and produce consistent image rendition at all ISO sensitivity levels.
Matti_JH kirjoitti: Maalis 28, 2021 10 : 22 Onko tuo joku pakkokohinanpoisto + softalla terävöitetyt ääriviivat.?
...Eli, sanoisin kyllä. "extra fine sharpness II" tarkoittanee lähinnä jpg kuvaa, mutta tekstistä saa sellaisen kuvan, että " PRIME V imaging engine and the new-generation accelerator" käsittelee myös RAW dataa, samalla tapaa kuin KP ja K-1II malleissa...Tai sitä on kehitetty edelleen.
Raffwal
Viesti Kirjoittaja Raffwal »
Tilattavissa nyt Topshotista 2199€. Huh-huh. Aika kova hinta APS-C -kameralle.
https://www.topshot.fi/product/17880/pe ... amerarunko
Raffwal kirjoitti: Maalis 29, 2021 12 : 15 Tilattavissa nyt Topshotista 2199€. Huh-huh. Aika kova hinta APS-C -kameralle.
Voi olla, jos vertaat menneiden vuosien hintoihin. Mutta ei kovin, jos vertaat modernien kinorunkojen hintoihin. Hintakehitys on ollut aika karua.
Raffwal
No minusta kova hinta nimenomaan full frame -kameroihin verrattuna.
Raffwal kirjoitti: Maalis 29, 2021 12 : 24 No minusta kova hinta nimenomaan full frame -kameroihin verrattuna.
No kaipa se on sen merkki, että sinun on tullut aika hommata kinokamera, ellet vielä ole niin tehnyt. Nykyään kinokennojen saantiprosentti on käsittääkseni kohtalaisen hyvä ja sen pinta-alan hinta ei ole enää niin iso kuin ennen. Tekninen peruste suurelle hintaerolle kennokoon mukaan on pienentynyt. Muutenhan noissa on samat roinat sisällä. Minusta on vähän erikoista, että Pentax on päättänyt jumittaa APS-C -kokoon, kun vakavasti itsensä ottava järkkärimaailma näyttää siirtyvän kinoon ja pienemmät formaatit kuihtuvat vähitellen puhelimien tieltä.
Raffwal
Jaahah, nyt hinta päivitetty 2099 €.
Lisää informaatiota tulevasta herkusta ;-)
https://pentaxrumors.com/2021/03/29/mor ... ouncement/
More Pentax K-3 Mark III camera leaks ahead of the official announcement that is expected at the end of March (March 31):
25.73 million pixel without low-pass filter BSI CMOS sensor
Equipped with the newly developed image processing engine PRIME V and Accelerator Unit II
Maximum ISO 1.6 million
100% field of view, 1.05x magnification viewfinder, 10% increase in brightness
Equipped with SR II with 5.5 steps of effect
Real Resolution
Low pass selector
3.2-inch 1.62 million dot LCD monitor, K series first touch panel compatible
101 points (25 points in the center cross) AF system SAFOX 13, low brightness supports up to -4EV
New RGB Ir photometric sensor with 307,000 pixels
PENTAX real-time scene analysis system that applies artificial intelligence technology
High-speed continuous shooting with AF.S up to 12 frames / sec and AF.C up to 11 frames / sec
A robust body with a dust-proof and drip-proof structure. The durability of the shutter is 300,000 times
Video is equipped with 4K30p, full HD60p, microphone terminal, headphone terminal
Bluetooth & wireless LAN dual communication
Supports charging of the camera body using the USB Type-C terminal
Safox. Eli mikään ei ole muuttunut AF:n suhteen. Real Resolution - keksitty uusi nimi pixel shiftille. Kuvanpaskomispiiristä versio kaksi.
Sääsuojaus mennyttä. Dust ja Drip proof = peruspeilitön hajoaa aivastukseen. AW ei siis toteudu tällä rungolla kun erikseen vihjataan näin. Ricoh on nyt sontinut Pentaksin.
ruutu
Viesti Kirjoittaja ruutu »
Maffer kirjoitti: Maalis 30, 2021 13 : 10 Safox. Eli mikään ei ole muuttunut AF:n suhteen. Real Resolution - keksitty uusi nimi pixel shiftille. Kuvanpaskomispiiristä versio kaksi.
Samapa tuo, kun tuohon hintaan on tarjolla peilillistä ja peilitöntä, kroppia ja täyskennoa ja mahtuu vielä lasitavaraakin mukaan monella valmistajalla kahteen tonniin...
magyar
Viesti Kirjoittaja magyar »
aikaarska kirjoitti: Maalis 27, 2021 10 : 04 Veikkaan, että tämä vasta lämmittelyä tulevaa kinokennoista K-1 markIII varten, joka ilmestyy sitten ensi vuonna, samantyyppisillä AF ominaisuuksilla...Ja varmaan myös kääntyvällä takanäytöllä.
Minäklin odottelen joko Pentaxin seuraavaa täyskennoista tai Sigma Foveon-täyskennoista. Useampi vuosi menty K-1:llä ja se on hyvä peli vielä monta vuotta joten sen puolesta ei ole kiirettä. Järki sanoisi että kannattaa pysyä Pentaxissa mutta jos Sigma ehtii ensin niin sinne voi mennä rahat. Kumman veikkaisit tulevan ensin ulos? Kummallakaan firmalla ei ole kovin hyvä ennustettavuus ollut viime vuosina :-).
Sigman Foveon oli ihan hilkulla jo tulla ulos. Ilmeisesti siitä oli jotain protoa ajossakin ja se olisi ollut 3x20MP RGB himmeli eli kirkkaasti paraslaatuisin kino pitkällä mitalla. K-1 MK3, jos toi Sigma FP-L jotain osviittaa antaa, on 61MP Sonykennolla. Eli toisaalta sitten saa tietää mihin se kenno oikeasti pystyy.
Sigma näyttää vain valinneen runkomallin mikä on kirkkaasti huonoin kaikista peilittömistä - se on suunniteltu asennettavaksi häkkiin sisään.
magyar
Maffer kirjoitti: Huhti 16, 2021 11 : 59 Sigma näyttää vain valinneen runkomallin mikä on kirkkaasti huonoin kaikista peilittömistä - se on suunniteltu asennettavaksi häkkiin sisään.
Onko jossakin ollut faktaa, että Foveon tulisi tuolla samalla konseptilla/runkomallilla? Eikö FP ollut enempi elokuvaajien laite...
mjuhani
Viesti Kirjoittaja mjuhani »
Alkaa kyllä nyt pukkaan hyvää kuvaa, kun tää Pentax ja toi Sigma saadaan myyntiin. Siinä on monella pojalla nopeasti ostohousut jalassa.
mjuhani kirjoitti: Huhti 20, 2021 11 : 23 Alkaa kyllä nyt pukkaan hyvää kuvaa, kun tää Pentax ja toi Sigma saadaan myyntiin. Siinä on monella pojalla nopeasti ostohousut jalassa.
Sigman kuvanlaadusta ei tiedä vielä paljon mitään. Muutenkin noi Sigman härvelit niin omituisia kameroita, että jaksaako niitä edes valokuvauskäyttöön ostaa?
Pentax on asia erikseen. Mukava nähdä ensimmäisiä kunnon arvosteluita, että miten hyvä se uusi kenno ja Pentaxin kuvankäsittelypiiri on...
magyar
Rohkenen olla eri mieltä tästä, vaikka itse olenkin molempien merkkien käyttäjä :-). Pentax on enemmän mainstreamia ja siellä kai ongelmat enempi mainosbudjetin suuruudessa, eli suuri yleisö on hukattu. Mutta Sigman laitteet ovat kyllä niin harvinaisia ettei käyttäjiä meinaa löytää netistäkään. Tosin niiden hinnat tuntuvat vuosien varrella vain nousevan käytettyinä, eli jonkinmoinen käyttäjäkunta on.
K-3 MK3 läpsii A7mk3:sta molemmille poskille:
https://petapixel.com/2021/04/24/a-high ... ny-a7-iii/
Miten tässä näin kävi ;D No ei toisaalta yllättänyt. KP + PS on jo 42MP Sonia edellä.
Maffer kirjoitti: Huhti 26, 2021 22 : 55 K-3 MK3 läpsii A7mk3:sta molemmille poskille:
höpöhöpö. turha edes selittää. tai vertailla erityisesti kinoSoneihin koska kaikki kinopeilittömät enemmän tai vähemmän samalla viivalla. Pentaxissa ei ole mitään muuta kun huijausta eli kohinapoistoa leivottu rautaan. Luulin, että inhoat sellaista?! Nää kohinapoistot ym. tehdään jälkikäsittelyssä, ei kamerassa. Pentax luisunut pilipali reitille, ja vielä lippulaivamallissaan! Tosin tämä oli aavistettavissa jo K-1II ja KP mallien kohinaleivoksissa.
Penatxin piti olla konstailematon valokuvaajan työkalu, nyt siitä on tullut joku B-luokan tuksu silkonihuulineen ja rakennekynsineen. Ilmeisesti muuten ei pärjää, ei saa varakasta herraseuraa.
Kyllä se näyttää ihan hyvin toimivan. Kinokenno ei ole vieläkään päässyt ISO3200-kipurajasta yli niin samaa sotkua ne nyt sitten tekee.
Mutta ei tuo ero kuvansuttauspiiristä tule. Jo X-T4 (ja 3) pistää Sonille hiekkaa rattaisiiin. Kyllä se on se kulahtanut 24MP kino mikä siellä grindaa. X-T3+ sama kenno kuin K3 mk3.
