OM-1
OM-1
Omppu julkaisee (kait) uuden kameran 15.2. Valikoiden lähteestä Photorumors.com:
A little over $ 2000
Non-stacked back-illuminated 24MP CMOS sensor
Stacked 20-megapixel sensor (IMX472)
The quad bayer structure improves low light performance by two steps.
120fps 12bit RAW DCI
4K 60p 10bit 4: 2: 2
Improved tracking AF
Advanced subject recognition AF such as animals and vehicles
EVF OLED electronic viewfinder, approx. 5.76M dots
3″ vari-angle monitor 1.62M dots (3:2)
Compensation steps (Body only): 7.0
Cross-type phase detection AF (1,053 points)
AI detection: Formula cars, rally cars, motorcycles / Aircrafts, helicopters / Bullet trains, standard trains, steam locomotives / Birds / Dogs, cats
ISO LOW (approx.80, approx.100), 200 – 102400
Silent sequential: approx 20 fps with selectable 5, 10, 15, 20 fps with blackout
Silent sequential SH1: approx 120 fps with selectable 60, 100, 120 fps without blackout
Silent sequential SH2: approx 50 fps with selectable 25, 50, fps without blackout
Buffer: silent sequential shooting 20 fps [RAW]: Approx. 108
Buffer: silent sequential shooting SH1 120 fps [RAW]: Approx. 92
Video MOV(MPEG-4AVC/H.264)4096 x 2160 (C4K): 60p, 50p / LongGOP (Approx. 202Mbps)
MOV (HEVC/H.265)4096 x 2160 (C4K):60p, 50p / LongGOP (Approx. 152Mbps) 30p, 25p, 24p / LongGOP (Approx. 77Mbps)3840 x 2160 (4K):60p, 50p / LongGOP (Approx. 152Mbps)30p, 25p, 24p / LongGOP (Approx. 77Mbps)
High speed movie: 240,200,120,100fps (1920 x1080 / MPEG-4 AVC/H.264) 200,120,100fps (1920 x 1080 / HEVC/H.265)
GPS info. Function: Yes
Battery BLX-1 Li-ion approx 520 shots / Quick sleep mode: approx 1100 shots
Memory Slot 1: SD, SDHC (UHS-I / II), SDXC(UHS-I / II)Slot 2: SD, SDHC (UHS-I / II), SDXC(UHS-I / II)
Dimensions (W x H x D)134.8 x 91.6 x 72.7mm
Weight 599g (CIPA standards, with 1x BLX-1 battery and 1 memory card, 511g (Body only)
Re: OM-1
www.43rumors.com sivuilta (FT5) OM.1 camera specs. Vaikuttaahan tuo erittäin kovalta ja hyvää boostia m43.
Key specs:
20mp IMX472 sensor from Sony (You can download the PDF here).
2 stop improvement low light with “Quad Bayer Structure”
120fps 12-bit RAW DCI
4K60P 10-bit 4:2:2
240fps 1080p
10fps mechanical shutter
20fps ‘normal’ high speed shooting
Hand held high res @ 50MP
Tripod HR @80MP
No 5MP raw mode
5.76m dot EVF with ~0.82x magnification
1.62m dot LCD
7 stops of IBIS
C-AF tracking sensitivity settings – 5 steps (whatever that means)
AI detection AF – Formula cars, rally cars, motorcycles / Aircrafts, helicopters / Bullet trains, standard trains, steamlocomotives / Birds / Dogs, cats
ISO range LOW (approx.80) – 102400
Electronic shutter (Silent mode)1/32000 – 60 sec
Improved AF tracking
astro tracking
Advanced Artificial Intelligent AF for animals,vehicles,etc…
Higher-res LCD panel
New battery(compatible with BLH-1)
price slightly above $2,000
shipment start in March
Key specs:
4K60P 10-bit 4:2:2
240fps 1080p
Tripod HR @80MP
No 5MP raw mode
1.62m dot LCD
7 stops of IBIS
astro tracking
Re: OM-1
4/3 Stacked BSI Live MOS Sensor ja onhan tuossa tulossa uskomaton tarkennus ja paljon muuta. Monessa asiassa varmasti ottaa kiinni Canonia ja Sonya. Ainut missä tulee turpaan on kenno koko. Nikonikin sais vähän mallia ruveta ottamaan muilta tarkennuksessa + etsimissä... Eikä mitenkään Nikonia mollatakseni kerta itsellänikin ollut Z6,Z6II ja Z7II. Z9 ei ole kokemusta, mutta se nyt meneekin jo aika eri hintaluokassa Canonin R3 kanssa.
Re: OM-1
Juu, kuuskytä ruutuu sekunnissa jatkuvalla tarkennuksella ja 120 kertatarkennuksella! Esittelyssä näytettiin, miten koliprin siivet mennee hiastettuna, kun viideoo tällää hd-laadulla 240 ruutuu sekunnissa! No oikeesti, kait siinä just niitä asioita mainostettaan parannetun, missä ollaan oltu jottain muita lippulaivoja jälessä, niiko noita älyllä ohjattuja tarkennuksen seurantoja, ISO-kestoa, tarkennusta muutenkii. Niitä tarkennusruutuja taitaa olla kymmenkertanen määrä, eli toista tuhatta! Jos puoletkii mainospuhheesta pittää paikkasa, ni hyvän kameran pukkaa markkinoille. Nyt ei oo muuta epäselvää ko lopettaako vanha lippulaivamalli toimimisen jo tännää, ko uus julkastii, vai toimiiko sinne asti, että uutta saap kaupasta. Minkä mainostettii tapahtuvan heti maaliskuun alussa. Miulla ois pari kuukautta vanhan EM1 mk kolmosen lisäks 750 euron käyttämätön lahjakortti tuohon paikallisseen...
Re: OM-1
Tämä on varmasti erinomainen kamera. Ilmeisesti viimeinen malli, jonka kyljessä lukee Olympus. ..Seuraavissa lukee sitten vain OMDS tms.
Henk.koht erityisesti kiinnostaa nuo laskennallisen valokuvauksen keinot (AI) , tälläistä ainakin luvassa:
Computational multi-shot modes
High Resolution mode (Tripod) - Shoots eight images with 1/2 pixel offsets to boost resolution to 80MP. Processed in camera, and can include Raw
Hand-held High Resolution mode - Shoots eight shots using image stabilization. Gives up to 50MP resolution. Processed in camera, and can include Raw
Live ND - Blends multiple short exposures to simulate one long one exposure, now with an ND64 (6 stop filter) option
HDR - Shoots between three and seven shots to capture a wider dynamic range, then tone-maps them down to a conventional SDR image
Live composite - Combines shot-to-shot changes between multiple long exposures to build up composites images that include details such as light trails.
For the first time, the OM-1 lets you use image stabilization in live composite mode.
Focus Stacking - takes a series of photos focused at different distances and combines them into an image where everything is in focus. The OM-1 promises twice the processing speed.
https://www.dpreview.com/reviews/om-sys ... ial-review
Viimeksi muokannut aikaarska, Helmi 15, 2022 10 : 48. Yhteensä muokattu 1 kertaa.
Re: OM-1
Dpreview:lla esimerkkikuva. Toki tuo toimii, mutta omaan silmään laittaa esimerkkikuvan tietynlainen siloiteltu etäisyys yksityiskohdissa. En osaa kuvata tuota tarkemmin, mutta katsomalla tätä kuvaa yksityiskohtien päälle muodostuu vähän kuin kalvo. Vähän samanlainen kuin tarkastelisi jotain jääkiekkokorttia paksun pleksikehyksen takaa.aikaarska kirjoitti: ↑Helmi 15, 2022 10 : 14 ...
Re: OM-1
Hei aikaarska! Nuo siun tuossa luettelemat AI-keinot on olleet jo EM1 mkii :sta asti olemassa! Eli löytyy EM-1 mk ii, EM-1 mk iii, EM-1X sekä kait EM-5 mk iii malleista. Ja toimivatkin ihan hienosti. Parannusta tässä OM-1 mallissa on noissa nopeuden suhteen, tässä uutukaisessa kun on uus professori töissä siellä kuorien sisässä. Paitsi tuo AnHan mainitsema sisäinen ND, se tuli vasta EM-1 mk iii:een, enkä oo ite vielä kertaakaan ees kokeillu, eli tuohon AnHan näkemykseen sen vaikutuksesta kuviin en osaa sanoa mitään.
Oikeesti Olympuksella kuvaavana minnuu kiinnostaa eniten tuon autofokuksen toiminta, siinä on yli tuhat tarkennuspistettä, ja luultavasti loogisempi ohjaus halutun tarkennusalueen määrittämiseen, ja tuo isojen ISOjen kesto pitäs olla ja parantunut. Menut on mietitty aika lailla uusiksi kanssa, toivottavasti ymmärrettävämmät. Normaalitoiminnoissa en niitten kanssa koe ongelmia, mutta jos noppeesti tullee tarvis jollekin toiminnolle, mitä tosi harvoin käyttää, sitä saa menuista kahlata, kun ei muista missä se taas olikaan. Noita toimintoja on kaikissa kameroissa paljon, ei niitä oikein voi muistaa, eli polkujen loogisuus ois se avain.
Edelleen kasvanutta nopeutta sarjakuvauksessa vähän kauhistelen; nytkin on hetken seisoskelulla lintulaudan lähellä kortilla kymmenen kertaa liikaa kuvia... jos 30 ois kohtuullinen määrä, ja nyt toteutuu 300, niin jos tuolla toteutuu 3000, niin tarpeellinen ois sellanen AI mikä karsii hutit automaattisesti, tai toisiaan toistavat, ja muuten vain turhat kuvat pois.
Mielenkiinnolla oottelen testejä kuitenkin.
Re: OM-1
Tuo esimerkkikuva ei taida oikein edustaa kunnolla sitä mihin live ND pystyy. Omat kokemukseni vähän samantyyppisestä vanhasta Sonyn ominaisuudesta ovat ihan positiivisia.AnHa kirjoitti: ↑Helmi 15, 2022 10 : 29 Dpreview:lla esimerkkikuva. Toki tuo toimii, mutta omaan silmään laittaa esimerkkikuvan tietynlainen siloiteltu etäisyys yksityiskohdissa. En osaa kuvata tuota tarkemmin, mutta katsomalla tätä kuvaa yksityiskohtien päälle muodostuu vähän kuin kalvo. Vähän samanlainen kuin tarkastelisi jotain jääkiekkokorttia paksun pleksikehyksen takaa.
Re: OM-1
Joo, nopeus on kasvanut ja eihän sitä tiedä vaikka ominaisuuksia olisi paranneltu entisestään muutenkin.JL Anttola kirjoitti: ↑Helmi 15, 2022 10 : 34 Hei aikaarska! Nuo siun tuossa luettelemat AI-keinot on olleet jo EM1 mkii :sta asti olemassa! Eli löytyy EM-1 mk ii, EM-1 mk iii, EM-1X sekä kait EM-5 mk iii malleista. Ja toimivatkin ihan hienosti. Parannusta tässä OM-1 mallissa on noissa nopeuden suhteen, .
Parasta tässä on kuitenkin, että järkkäriin on laiteltu näitä AI ominaisuuksia. Oikeasti niitä voisi olla enemmänkin, kaikilla johtavilla merkeillä.
Re: OM-1
Siloiteltu kalvo ND-kuvassa? Pleksilasi = tuhnu linssi ja perinteisen digin vähemmän etäisempi kuva on taas enemmän kohinaa pitkässä valotuksessa. ND-suotimet joutaa kokonaan jorpakkoon fyysisenä suotimena ikuisesti. Ehkä niille on aurinkoa kuvatessa tai hitsaustouhussa joku käyttö.
